New to forum have 2004 SE with about 100K. Engine runs well. Will stall with any prolonged. Idling either in drive or nuetral. Cleaned idle solenoid wasn't that dirty, replaced map sensor, cleaned throttle plate, plugs look good. Battery is on scan code but installed battery charger while idling with no help. Needs an 92 sensor, but could that effect idle. Changed fuel filter also. Thanks for any help
