- Moscow
- ID
- 2012 Ford Focus
2012 Ford Focus
Hey all somehow I messed up. I was recharging the AC on a 2012 for focus. Located what appeared to be the low pressure AC valve and attached the pressure hose to check pressure. I was holding the lever and accidentally released pressure. Green fluid came spewing out. I stopped and detached and went into the driver's seat. While I was sitting there warning started popping up about the transmission. I quickly shut it off only to not be able to turn it on again. Car won't turn over and electronics won't work either. Suggestions??
