During my last race I was plagued by overheating issues on my 2003 Focus 2.3l. Now I am trying to cover all my bases for the cause so that this does not happen again. Two stages into the rally my temps sky rocketed and I had to back off and run the heater. I ended up missing two stages while the car cooled down and to let the coolant stop boiling. After I finished the race it seemed like my expansion tank had a leak in it. So I changed that, then for peace of mind I changed the water pump, and flushed the radiator out, and installed a heat extraction vent in the hood. While I was down in that area I removed the whole AC system.
Everything seems okay for now. But after thinking about it I can not remember the fans kicking on at all during the race. I can power the fans directly and they turn on when jumping the fan to the battery. but after driving it around and trying to get them to turn on I have not seen them on. I am not overheating during normal driving, but I'm afraid it will overheat during a race. I have read that you can get the fans to go on by turning on the AC button and the re circulation button. But the fans do not turn on. But I have also deleted what I could from the AC system so i'm not sure if it would still function like that. Does anyone know what I should check first? I at least know that the fans can turn on.
