- Schrozberg
- Non-US
- Germany
- Ford Focus MK3, 2015,1.5 TDCI,120ps
Hello
Patient: Ford Focus Mk3, 2015, 120ps, 1.5 diesel
Symptoms: AC does not work (does blow cooled air), compressor and fan do NOT turn on.
What I've done so far:
1. Diagnosis. I have NO error codes on the car, none whatsoever.
1a. I also read the information in real-time, the video with the data will be posted in a link below.
2. I checked ALL the fuses in the 3 fuse panels: under the hood, in the passenger compartment, and in the trunk. I have NO faulty fuses!
3. I checked the pressure in the installation, and the pressure is correct, KOEO with AC off, and the pressure is identical on the HI and LOW sides (18 deg. C, +-30 PSI).
4. I replaced the pressure sensor (the fastest part to change so I have no other doubts regarding the sensor). Conclusion: the old pressure sensor is either good or the new one is defective. Probably both are good
5. I optically checked the 2-pin plug that goes into the climate compressor and the harness and I did not find any broken cable, eaten, cut, etc., under the car!
6. I measured if the compressor receives voltage. Here I discovered the first bug: NO, the compressor, on that 2-pin plug, does NOT receive voltage, although according to the button pressed and confirmed by the diagnosis, the command to start the AC exists!
7. To rule out the compressor/electromagnet, I fed the compressor directly, with other wires, from the car battery, and immediately the electromagnet/clutch engaged and started spinning.
- Problem 1 for point 7: The fan still does not turn on
- Problem 2 for point 7: although the clutch/electromagnet/compressor is powered directly, the car does not cool down, only normal air enters...
- Problem 3 for point 7: Even though the compressor is powered, the pressure on the HI and LOW remains relatively the same. Theoretically, once the climate is on (the compressor is running) the pressure on the LOW should drop to 0 and the HI should rise. NO, they remain the same
Other info :
8. With Forscan and Launch, the reading at "x1000 CACRP" is 399.0, with slight oscillations up to 401.0 (expressed in kPa). Ist the same when I have the engine off (Key On Engine Off) or with the engine running and if I'm not mistaken even when the engine is on and the AC is "on". („on“ meaning that it is set to a minimum temperature, set on auto or manual with maximum speed and the AC button pressed ...
9. The Pressure Sensor voltage is about 0.82V - 0.88V as shown in Launch and Forscan
What I haven't been able to test yet: relays. I'm going to get a relay tester and check those too.
I have no ideas left. I ask if anyone knows something, can give me an idea or if anyone has some experience, please give me some advice. To shorten the list of tips: NO, I won't go to the service, I won't go to the dealership, I prefer to remove all the AC from the car than to go to the service! 😄
Thanks in advance to everyone who takes the time and actively and positively contributes with any idea to solve the problem!
Info, pictures, and videos can be found in the attachment and in the links below:
Diag Data Stream https://www.youtube.com/shorts/obK4-gSmNP4
Diag Data Stream 2
Refrigerant Pressure
(important to mention: here I was powering the compressor/clutch externally with 2 wires directly from the car battery)
Additional info but I don't think it's very relevant: 2 years ago my climate radiator was changed under warranty. Somewhere it had a hole where the coolant was lost. As can be seen from the pressure test, I did not lose any pressure and it does not seem to be a problem.
Other info :
Diag Data Stream 2
