- London
- Non-US
- United Kingdom
- Ford
Hey everyone, I need a bit of help. My car won't crank after I replaced the engine and wiring loom with an ECU kit from another running car. I've swapped the BCM, fuse box, ignition button, stability module with key, and immobilizer module, and programmed everything with Ford diagnostics. It still won't start. Next, I'm planning to replace the ABS pump, airbag module, and key receiver module. Any other suggestions or ideas on what might be wrong? Thanks!
![](http://uploads.tapatalk-cdn.com/20240628/84b5ba157f3cb5734a47bef96053ce97.jpg)
![](http://uploads.tapatalk-cdn.com/20240628/16ac36204989c2d6875140fb86ff86c4.jpg)
