ABS light on
Kurly326
Michigan City
2007 Ford Focus SE
My 07 Focus has the ABS light on, just wondering what you guys think it is. I was thinking speed sensor or ABS sensor. Thanks!
If it was a Speed sensor which ABS uses a similar fashion to help with Traction Control - you'd have problems with ODO or Speedo - but ABS itself uses power so the tell-tale light can mean many things.
You'll have to grab a OBD-II scanner and see if any codes can be found - it would help isolate the problem.
