Brake Booster Grommet
rulinon
Richmond
2000 Ford Focus SE
My 2000 Focus SE SOHC (although "SOHC" doesn't matter because the "DOHC" uses the same brake booster) needs a new RUBBER GROMMET for the Check Valve/ vacuum tube connection into the Brake Booster.
I've been searching online for DAYS and have YET to come up with anything that is actually designed for that specific era Focus OR one for a DIFFERENT vehicle that someone has found to work in that model Focus.
Does anyone KNOW of SOMETHING that will work? I thank you in advance.
This "might" fit - at least you can get it in your hands a look at it...
Find this at AutoZone​
